Link Color Problem with smartphone site
on my site the links are not colored, despite having fixed the thing with tagdiv builder, I noticed that on the pc site the problem is solved, while on the mobile site the colors of the link and the changes to the theme are not changed. Could you help me figure out how to fix this? My website is http://www.vadoanapoli.it
thank you
Edit the page with TagDiv Composer, click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB ; there you can see your mobile version and you can edit the elements there.
In the theme panel, if you access Theme colors -> General theme colors, then there is a setting called ” Theme accent color ” which changes the hyperlink text color and also various other elements which use that color: https://forum.tagdiv.com/theme-colors-introduction/
From the pc I see the links of the color I have chosen, also in the smartphone section. But when I go to the smartphone the links are black you can also look at this article at the bottom of the page https://www.vadoanapoli.it/sorrento-una-meta-per-le-vacanze-estive/
Please edit them in the TagDiv Composer link color and also in hover.
Or please provide a screenshot of the link you mean, so I can help you efficiently.
