If you type and save your text in ‘Text with Title’, the page will be created well.
However, if you insert a ‘link’ into the letter you entered afterwards, the link will not take effect and there will be no change.
The link does not appear.
A bug is occurring.
If you enter only plain text or change the color of the text in ‘Text with title’, it saves well and does not cause any problems.
However, if you save it after inserting a ‘link’ into the text, it will continue to buffer and the page will not be saved.
I recorded a bug scene and uploaded it to YouTube. Please click on the link and check. Please give me a solution.
Please continue the discussion on one topic. I did a test and for me works, please check if you don’t have an error https://app.screencast.com/MJYTNL5Xr5JRS
Also, if the composer is not saved, please check the console; please check this topic -> https://forum.tagdiv.com/topic/tagdiv-composer-does-not-save-only-content-of-homepage/
If you just insert and save the link, the page is saved and the link works fine.
However, if you specify “Settings that open to a new window” in Link Settings and click Save Page, the page will not be saved. Problem occurs with ‘Save content’. The buffering continues.
1. Disabling multiple plugins didn’t fix the problem.
2. As you told me, I joined Cloudflare and set it up, but it didn’t work out.
3. I contacted the hosting company and disabled the firewall, but the issue hasn’t been resolved.
I tested with the setting to open in a new tab, I think that you have there some issues there.I would like to take a look, can you please contact us via email at contact@tagdiv.com and provide the wp-admin access?
I added a new user to my homepage.
An email has been sent to contact@tagdiv.com .
* The email address I sent is bromaru@naver.com .
* The email is titled “Mail to Provide wp-admin Access”.
* Administrator Access Home Page Address: https://bromaru.kr/wp-admin/
There was a problem with the ID and password for the new user I sent you earlier, so I created a new user again.
And I emailed contact@tagdiv.com again with the ID and password information for the new user.
The title of the email is “ID and password for wp-admin access of the new user you added”
Administrator page address: https://bromaru.kr/wp-admin/
* New user ID: tagdiv3
Seems you have this error https://codedamn.com/news/backend/how-to-fix-cors-error, please solve it https://wordpress.org/support/topic/cors-access-control-allow-origin/
It is difficult for me to understand and implement the professional knowledge and solutions on the page you told me.
You always provide only links.
Please tell me the proper solution.
It’s not being solved.
I’m running out of time. The situation is not good. Tomorrow is Saturday. Consultation is restricted.
This reply was modified 3 years by
bromaru.
The problem has been resolved.
I asked the hosting company a few days ago and turned off the hosting firewall. But the problem was not solved.
So I checked about the firewall again, and there were two firewalls for hosting. One was a firewall for http and the other was a firewall for https.
I was in a situation where I only turned off the firewall for http.
So I tried to solve the problem again after turning off the firewall for https.
Fortunately, the problem with the link has been resolved.
