Link Problem after updating theme
Hi, i have a strange problem…after updating theme all seems ok but every link (post, menu, etc…) on the homepage does’nt work. If i open that links on another page they are ok…but if i clik on the link normally nothing appen…like i have no clik.
Can you help me please?
my site is http://www.falcri-is.com
I’ve checked your site and found a js error in browser console: http://screencast.com/t/mKJlLjnNO3SD Please make sure that you update the theme according with our documentation: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/ also try to deactivate all plugin except Visual; Composer, clear all caches then test the site again.
Let us know how it goes.
Tnx a lot…now all is ok
I write solution for other people:
1) Delete theme folder (newsmag)
2) Upload last theme folder version
3) Delete plugin’s folders (only plugins inside theme)
4) Upload plugin’s folders new version (only plugins inside theme)
5) Deactivate all plugins except “Visual Composer”
6) Delete Cache
7) Reactivate every plugin (onebyone) to discover wich one creates problem (in my case was Eventon)
8) Activate all plugin except wich one creates problem.
9) Control if there is an update for this plugin and in case update it and activate it
Glad you have managed to solve this.
Thanks for letting us know and for sharing your solution here.
