Hi team, I am facing a wierd issue on my website. When I am opening some old links which i already redirected few years back. Until page is not scrolled, the old link doesn’t changes but when we scroll down the new links comes up and changes the URL automatically. You can also check
Old link: https://www.electronicsforu.com/electronics-projects/getting-started-kinect-opencv
New Link: https://www.electronicsforu.com/electronics-projects/software-projects-ideas/getting-started-kinect-opencv
Once you open old link, just wait for 1-2 min and then scroll, the link will automatically changes to new one. If we don’t scroll down the link will be as it is with no change.
Yes, this is true because this is working like that. You use the article auto-load function there, which is loading the next or previous post. When you scroll and a new post is loading, the link will change. That function can be disabled from here: https://prnt.sc/23EUcDSbHCSY
We would like to investigate this issue.
– admin url and credentials
– cpanel url and credentials
