Links not Showing in Comment Section
I am using Newspaper theme & Getting genuine comments on my blog https://bestfoosballtables.co/ but whenever I reply someone with any link of my published post….it doesn’t shows. Please Help
I have made some tests in this case, and everything seems to works as expected. Please check here -> https://www.screencast.com/t/DOSxEkJ6z Make sure that you are using the latest version of it, remove all of the untested plugins, clear all the caches, purge CDN files and check the results.
