Lists look different from body text
Hi!
I would like the lists on my blog to look the same as the body text.
See here, for example: https://www.fuckdiestudieschuld.nl/no-spend-november-in-nederland-wat-waarom-en-hoe/
The line height is different, and maybe other things are different too?
How can I change this? Why isn’t it the same?
You can increase the line-height for the lists, in the theme panel font settings
– https://prnt.sc/pqlna0
Try it with 30px, they will be similar to the paragraphs – https://prnt.sc/pqlo07
Let me know if you have more questions.
That worked, thank you! 🙂
Hmm, a follow up question. Strangely enough, the lists on pages that I create with the Composer still look different.
See this page: https://www.fuckdiestudieschuld.nl/over-dit-blog/
Any thoughts?
Ah, I figured it out. Somehow I have to change those settings on the individual text thingies instead of in the general settings. Strange. Anyway, never mind.
