I, after disable my adsense i have this problem
https://www.pcusb.it/wp-content/uploads/2017/12/Foto.jpg
The background color grey is inside the header, why?
Thank you……
This could be a plugin conflict or a customization problem so please disable all plugins except the page builder, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
