Hello TagDiv,
I’ve made amendments to my site (glitched.co.uk) and as you can see, the Big Grid has had some CSS tweaks in order to show a different style.
However, I have noticed that upon loading (mainly on Chrome and Safari), there is a slight lag when this loads and it shows the Big Grid before the CSS changes are applied.
Is there any way for me to get rid of the way the original big grid loads so the user only see’s the customised version?
Hello Glitched,
Unfortunately, I cannot see the problem which you have reported above because I did not find our theme installed on your website from the link provided above. In the future, if you want to avoid this flash, all your customizations should have directly put in style.css.
Hello Glitched,
Unfortunately, we cannot offer support for your custom modifications, sorry! Please notice that each of additional change might influence the proper functioning of the theme if this is not right done. As a general rule, please keep in mind that the CSS working in cascade (Cascading Style Sheet) and the first time take the code from style.css and then take your customizations that you have changed from Theme panel or through custom CSS area or your Child Theme and that’s why you get that delay in loading page. So, if you want to develop more levels in our theme and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
