Load lag (color problem)
Hello! I have changed my site main color to pink, but everytime I load the site, I see the blue “default” color before the pink one. This slows the site loading, but looks really bad. Anyone has a clue what might be causing this?
Thanks in advance!
Hi, this has been covered before (search forum), for this exact same question. This is usually due to a delay in the color over-ride loading so you see a flash of the default color; more noticeable if using a child theme due to the CSS redirect. I think the main “right” solution is to specify some colors in the styles.css file if you know how to do that.
Marius will have better answer, but you can search forum as this identical question has been asked before 🙂
@nicoms91
As Christopher suggested the best way to fix will be to change the colors using this method https://forum.tagdiv.com/topic/about-default-theme-colors/#post-17657 follow this topic will lead you on how to do it.
  • This reply was modified 12 years by Lucian.
