Load more ajax not working
Site:lemonoid.net
Issue: Load more button from the home page takes me to the top of the website and nothing happens. Tried both on mobiles and different computers to no avail.
Please check!
I have checked your site and found this js error in the console: http://screencast.com/t/LujLAWIL This comes from a plugin google-captcha, so please deactivate this plugin, clear cache and see if it works.
Also you can try to disable all plugins, leave only Visual Composer active, clear cache and purge your files if you use CDN.
