'Load More' Ajax Repeats Posts
I’m having an issue on our website in that when we click the ‘load more’ link, there are duplicate (repeated) posts. So, if I click load more two or three times, I start to see the same posts I saw on the first page.
See an example here: http://www.betterretailing.com/your-store/ beneath the ‘More ideas’ heading.
Anyone had this issue or know how I can fix it?
I have checked the setting of the block in Visual Composer and they all seem OK. They’re getting the posts from a category, sorted by ‘latest’, ‘limit post number’ is set to 3.
Any ideas?
I have managed to recreated this and seems that we have a problem with the unique articles feature as it generates the same issue on my tests also.
For the moment I have added this on our issue list and we will investigate it and hopefully we can will fix this until the next update.
Sorry for the inconvenience and thanks for understanding!
Hi there,
Has there been any progress on this?
Its a bit of an issue for me and I’ve had several readers of my site complaining
e.g. http://www.betterretailing.com/news/
We tried to fix it but no solution yet, we’re still looking for it. Until then, depending on how your page is structured you could try to use the offset feature to achieve a similar result – https://forum.tagdiv.com/unique-articles-and-offset-newspaper/
Thank you, Emil G.
