Hi Team,
Load more does not work properly in translated version of our website. Can you please check.
Our website has two languages EN and DE.
Proper Working URL (EN) : http://onloc.mydemosites.in/real-estate-gallery/
Another version i.e. DE does not work : http://onloc.mydemosites.in/de/immobilien-galerie/
Load more does not work in second link. Please check
If you are using the WPML plugin, then it is an option that need to be use this option can be find here https://i.imgur.com/IreIOd2.png -> https://i.imgur.com/kvW1R7H.png
I hope this will help you!
