Load more button for Grid Flex 6, Block 14 Load more button color option
Hi team,
Please see below queries:
Grid Flex 6
-is there a way to add Load more button?
Block 14
-is there a way to make the culumns 4 or 5?
-can we add a hover color?
-can we adjust the image padding/ space between?
-customize Load more button
*border color
*remove icon
Regards
  • This topic was modified 5 years by indochine. Reason: additional query
In the Grid Flex 6 element isn’t that option for the Load more button, only in Block 14 element.
If you use Block 14 element you can:
– add a hover color from here: https://www.screencast.com/t/V5q38AbJlq1G
– customize Load more button only from Style tab from the element
I recommend you to use Flex Block 4 to have more options to customize the design. With a few options then you can obtain the same design of Block 14 and it also has the settings you are looking for.
Hope that helps you!
I already set that option but didn’t work. See image. That option is for header, not for the image/post.
  • This reply was modified 5 years by indochine. Reason: additional text
It seems this is a bug at the moment in our theme. Our developers are working on it. As soon as we have an update, we will let you know.
We are sorry for the inconvenience!
