I have two columns on webpage with FlexBlock 5 in each. Which CSS code I have to write to make “load more buttons” bigger and with full block width?
Here is the custom code for load more button -> https://www.screencast.com/t/BLeMpaj62x
from style section you can set the font on load more button -> https://www.screencast.com/t/UcuVTBfjc1
.td_flex_block_5 .td_ajax_load_more{
width: 100%;
Just add the code in Newspaper>theme panel>Custom code>Custom css and all FlexBlock 5 will have the load more button with full width.
