Load More – Fade to White Problem
page is fade to white when i press load more button and scroll down. why this is happening? How to fix?
MY SITE
Gif: Problem Animation
I’ve checked your site and found a js error in browser’s console: http://screencast.com/t/pRikF3j6 Try to deactivate all plugins except Visual Composer, clear all caches, purge cdn files if you’re using then test the site again.
Let me know how it goes.
Disabling plugins doesn’t help. I delete everything on homepage and then add everything again. Now my problem is solved. This is weird. 🙂
Thanks for your help.
Glad you have managed to solve this.
Thanks for letting me know and for your message.
