Hey there,
When clicking the “load more” button on the various sections on my website’s homepage loads the posts but does not show the images. Instead, it shows the title of the image as input in the metadata.
The first posts that show before you scroll do not have this issue, but scrolling or ‘loading’ more articles does not load the images with it.
This has been going on for a while, and I’m not sure how to fix it. Thanks in advance for your time and help.
I think the problem is caused by the plugin Site Ground Optimizer because seems you use it -> https://i.imgur.com/uZTpO2N.png and this plugin interferes with the Ajax request, so please do a test without this plugin, clear the cache, and check after.
