Load more posts Repeated
Hello Please have a look at this :
http://excelsiornews.com/jammu-videos/
When we click load more button , the above row is repeated
FYI: I have used Big grid 5 above (Three posts)
Block 15(below 6 posts; the problem is in this block)
I have used the same in other pages but it is working fine in other pages
Try to deactivate all plugin except Visual Composer, clear all caches, purge cdn files if you’re using then test again.
Let us know how it goes and if the problem persist please send us an email at contact@tagdiv.com with your login credentials and we will inspect this issue as soon as possible, also include a link to this topic.
I have tried deactivating all the plugins but still experiencing the same problem
I would like to add one thing that i have used same category in both the blocks In above box
The first three posts are fine:
But in 2nd block the posts are starting from 4th video (The first three are automatically skipped in this block)
Please address us via email at contact@tagdiv.com including a link to this conversation and also give us wp-access so we can have a closer look at this and we will get back to you as soon as possible.
I have addressed the same to your email id
I have not received any reply neither the solution??
Hello Rahul Dogra,
I have checked our email address and I did not saw any email sent from you. Please re-send there your request and we will answer you as soon as possible.
Hello Catalin,
This is for sure that you have got the email or maybe you do not know about the details.
In my wordpress dashboard. There is a private Page Created as “tagdiv test”
If you had not received my email them who created that page ? and that page has the same contents as the page I am experiencing problem with.
FYI: https://s10.postimg.org/utydfenjd/tagdiv.png
Anyways , I am sending details again
I have sent the details again. No reply yet again
I’ve replied you via email!
