Load More Posts throw Ajax
Hi, I need disabled or extend de life of td_magic_token
When a block has pagination by ajax, there is a parameter “td_magic_token” in the request. This process dont work good with CDN Cache, bacause the life of cache is greater than life of this token. This causes, after the token expires, the paging does not work.
Is there a way to remove the token (make the request without token) or to extend the life of the token?
You should be able to change that from here: wp-content/plugins/td-cloud-library/assets/js/js_files_vue_theme_panel.min.js As you can see here is the line: https://i.imgur.com/ynTrV97.png
I hope this was helpful1
