"Load More" to show more articles + ad box
I have a block that shows 6 posts with an ad box showing a banner underneath. Beneath that, I’d like to have a “See more” button that displays 6 more posts (I would offset posts = 7) and another ad box and another “See more” button…repeat. Is the way to do that?
Hello !
We recommend you to use Flex Blocks for this: https://www.screencast.com/t/wf0tj04g3 ;
You can add more flex blocks and use the offset function and the preloading.
But when the new flex box appears, I also want an ad box to show with it. Is there a way to do that?
Hello !
Unfortunately this option is not available at the moment.
Thank you for your understanding !
