Yes, does are the general font family and as you can see in the code file ( https://www.screencast.com/t/dDy0HdCQAb96 ) and in the documentation https://forum.tagdiv.com/font-customization/ there are local load.
Hi Calin,
Thanks for this information! Could you also please tell me which type of the Roboto front you are using for the post titles by default? I tried it with Roboto Regular but it seems to be a bit smaller than the one you used. The following are available on Front Squirrel:
Roboto Thin free font
Roboto Thin | 1040 Glyphs
Roboto Thin Italic free font
Roboto Thin Italic | 1040 Glyphs
Roboto Light free font
Roboto Light | 1043 Glyphs
Roboto Light Italic free font
Roboto Light Italic | 1043 Glyphs
Roboto Regular free font
Roboto Regular | 1038 Glyphs
Roboto Italic free font
Roboto Italic | 1043 Glyphs
Roboto Medium free font
Roboto Medium | 1038 Glyphs
Roboto Medium Italic free font
Roboto Medium Italic | 1043 Glyphs
Roboto Bold free font
Roboto Bold | 1038 Glyphs
Roboto Bold Italic free font
Roboto Bold Italic | 1043 Glyphs
Roboto Black free font
Roboto Black | 1043 Glyphs
Roboto Black Italic free font
Roboto Black Italic | 1043 Glyphs
Roboto Light Condensed free font
Roboto Light Condensed | 1045 Glyphs
Roboto Light Condensed Italic free font
Roboto Light Condensed Italic | 1045 Glyphs
Roboto Condensed free font
Roboto Condensed | 1045 Glyphs
Roboto Condensed Italic free font
Roboto Condensed Italic | 1045 Glyphs
Roboto Bold Condensed free font
Roboto Bold Condensed | 1045 Glyphs
Roboto Bold Condensed Italic free font
Roboto Bold Condensed Italic | 1045 Glyph
Sorry I forget to link: https://fonts.googleapis.com/css?family=Open+Sans%3A300italic%2C400%2C400italic%2C600%2C600italic%2C700%7CRoboto%3A300%2C400%2C400italic%2C500%2C500italic%2C700%2C900&ver=9.0_d82
Thanks for your link! To sum this up, the following custom fonts are necessary:
Open Sans italic (300-700)
Open Sans normal = Open Sans Regular (300 -600)
Roboto italic (400-500)
Roboto normal = Roboto Regular (300-900)
Only the 4 fonts (Open Sans italic, Open Sans regular, Roboto italic, Roboto regular) must be uploaded, the different sizes can be selected from the theme panel.
If you use google fonts, you can get them all from google, with all size, but if you don’t you must use custom file like dose with .woff extension
https://www.screencast.com/t/a6fqLlQgsWAm
https://www.screencast.com/t/HgOvgm3dz
Correct, but using Google Fonts that way is probably not GDPR compliant. That, of course, depends on how the individual EU Member States interpret the GDPR. In Germany, the rules may be a little stricter and there are already some cases at the courts (for linking Google Fonts), but it will certainly still take some time before a judgement in principle will be reached. But therefore I wouldn’t recommend it.
Another advantage could be that fonts on the same server should load faster than linked ones.
I figured out that in order to load all default used fonts locally, the theme would need 6 spots for uploading custom fonts. It provides only 5.
Font type and weight settings are not working for uploaded fonts. E.g. You can’t generate “Roboto Bold” by setting “Roboto Regular” to 700 weight (corresponding to Roboto Bold).
So the needed fonts (used by tagdiv default) are:
Open Sans Italic
Open Sans Regular
Open Sans Bold
Roboto italic
Roboto Regular
Roboto Bold
6 Fonts but the theme provides only 5 spots. Please add another spot with future updates.
