At the bottom of each article, immediately after the “related articles” section, load entire posts that have nothing to do with the open post, how can I disable this opening of entire articles before the footer?
please see attached sample video
reference link to the post
https://www.sadefenza.org/2020/09/le-banche-centrali-vogliono-sostituire-i-contanti-con-la-valuta-digitale/
thank you
If you are referring to infinite loading, you’ll need to edit the single post template with tagDiv Composer and disable the infinite loading.
-> https://tagdiv.com/infinite-loading-for-single-posts/ from post -> https://i.imgur.com/yIf6fA3.jpg -> https://i.imgur.com/KeclHLS.jpg -> https://i.imgur.com/4jHIHFY.png
Let me know the results!
