my website’s login is not acting as it should act. I input the login details but it just is loading and never allows the user to enter. Either it says incorrect user/pass but i am pretty sure that is not the problem. You can check yourself by visiting themarkhortimes.com/login and enter any random login details, it will just load and not take you anywhere. It just keeps loading. Also the login page does not show sign up option, Please give me a solution to that too, i have enabled the sign up option and if it try to enable it in the wordpress general settings, ‘anyone can register’ option, and save the settings, it returns back to disabling that option.
Hello @ameeralisalman!
– admin url and credentials
We will take a look and try to help you asap.
