while i try Sign in / Join then the popup window comes. I have filled the login credetial then it shows “PLEASE WAIT” but nothing forward. User wait and wait…… nothing happen.
Later on if user refresh the screen from browser then it show the user login. But when the popup came it was only showed “PLEASE WAIT”
For this our user are getting confused. I need a quick solution for this
Please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Then test the login again. It could be a plugin conflict affecting the login widget. You can also increase your system status parameters as this guide suggests: https://forum.tagdiv.com/system-status-parameters-guide/
