Logo not showing on my post pages on mobile please help
Hello I have set my website up and everything is going great, but I have a problem. My logo and header are perfect on all my pages, but if I click on a post my logo doesn’t show at the top and I get the standard header with newspaper showing in the logo section. I’m sure there is an easy explanation for this but I’ve been trying for a while now. Thank you 🙂
Please check if you have set the header to be global from Manager (Website Manager) – Header -> https://i.imgur.com/OX5p6ty.png
Also, for mobile please let me know if you have the mobile theme plugin activated, if yes, and you want to use it, to set the logo you need to go in Theme Panel -> Mobile Theme Header -> https://i.imgur.com/Vv4BpE1.png
Also, please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/ and choose what mobile version you want.
Hope this helps you!
Hello, they’re thank you for the reply. Yes, I have my header set to global exactly how you explained it. It’s perfect on my pages but soon as I click a post the logo disappears and it shows the newspaper logo instead. I haven’t got the mobile theme activated because it messes my page up and makes it nothing how I want it. So I have it off and I created my mobile pages using the Tagdiv composer and everything is perfect apart from this logo problem when I click on post thank you
If you create mobile templates/mobile pages you need to convert the existing header/footer like this => https://www.screencast.com/t/HrjOBNayd
Also, please provide the link to your website.
Hello I have done this but it’s still not showing on my post for some reason its very frustrating. My site is propunters.co.uk. I hope there is a solution for this thank you
Hello, don’t think I’ve ever been so worried to edit something so much in my life ha. I have no idea how all this coding stuff works. All the articles just make no sense to me really. I have installed the Htaccess plugin on WordPress as it looks like the safer option so I can test it first when I’ve tried the code.
I have no idea what I should be putting in the htaccess do you know please exactly what I have to type in I hope you can provide the code and I can just copy and paste it in and the problem is solved thank you very much for all your help. I would be completely lost without you thanks
I have just gone ahead and followed one of the articles and I put in the code pressed test it said successful so I thought great and saved the entry. It automatically said error your site wont work and to follow the instructions. So I deleted the code I entered that I put in as advised on the instructions on wordpress and now it has came up with a 500 internal server error. Have I completely messed my website up I really hope there is an easy fix cant believe this has happened thank you
I am convinced that I have completely lost my website from following the instructions. I’ve put my backup file in to the public_html and still getting the 505 internal error and I cant access my wordpress admin panel either. I hope this can all be fixed as soon as possible thanks
Ok well, I’m happy again lucky for me my web host does an update of my website every day so I have managed to restore my settings from yesterday 🙂 Could you please help me tho how I can fix the CORS problem thank you very much and apologise for all the messages its been a stressful few hours ha. Thank you Anamaria
I just checked and it seems that you no longer have those errors in the console https://i.imgur.com/C2uQDk8.png . It seems that there were no such problems in the backup.
Ok great but was hoping that doing this was going to sort my problem out, of having no header on my post. I have done everything that you have said and still my header and logo are not showing up on my post. Its really frustrating I’ve tried everything with no joy thank you
Hello I have managed to fix it so thank you very much for all your help. I have a small strange problem now tho. I have made a footer on my page that I am really happy with but for some range reason on my football page the footer is not showing it on mobile its showing my old footer. But every other page and post is perfect except for the football page. Do you know what the problem could be very strange for it to only be happening on football thanks
I just checked and seems you resolve the problem with the footer -> https://i.imgur.com/OWixY26.png
Viewing 14 posts - 1 through 14 (of 14 total)
