Hi, I get a 404 error page when I want to disconnect from my site https://bpe.fun
could you help me please ?
thank you in advance
I’m not a forum admin but,
it maybe that you have a child theme activated (with update to v8.5 we have some issue on child theme).
Try temporary to re-enable main theme.
So could you send me the plugin or code CSS you’ve used in your contact form (https://bpe.fun/nous-contacter/) please?
The theme uses the default WordPress login functionality, so most likely this is happening on a default theme as well. Please try as a quick test to see if deactivating all plugins except theme plugins has any effect. Maybe a plugin is causing the issue.
The default behaviour is to redirect to the homepage after the user logs out.
There are some issues with the child theme functionality after the latest theme update. We are working to provide a solution as soon as possible. Sorry for this inconvenience.
