Had previously reported a problem with a loop in Theme Panel…something I took care of through my main site’s Wordfence settings.
But now I’ve got that loop problem in trying to use the Font Settings. Even deactivating Wordfence in my main domain makes no difference, nor does deactivating other plugins.
‘and yes, everything else is up to snuff in that the settings in WP Config and at my host are all as they should be.
BTW, it’d be extraordinarily tedious to have to manually go from one to another determining what colors to apply to what font in whatever sections. Doing a basic set of link hover colors in CSS does the job but poorly for the moment.
Please help.
Hello cyberfyber,
Please check the system status parameters to be according to our documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/
Yes, I mentioned in that last post regarding the other loop problem that I met and even went beyond some of the system parameter requirements.
BTW, just now disabled all other plugins again and deactivated wordfence AND cloudflare for good measure. Still the same problem.
Sorry, should’ve posted earlier. Last night I moved the theme to my main domain and it’s all working as it should now. As far as I can see. đ
Thanks for help.
