Low image quality on homepage and sidebar, but high quality inside the post
Why are the images on my homepage or in the sidebar lower quality, but when I open the article the same image appears with much better quality? Is this related to WordPress image sizes or compression?
https://albaniatoday.al
If it is an image that is slected it can be because the image is not selected in full size, and it is used as a thumb https://prnt.sc/zdg-XBLi53E3
Now if is a block, then you can edit teh page with tagDiv Composer, select the block and in the layout tab look for Image size. From there, select teh image size/thumb you want to be used – https://prnt.sc/g8z1ti5KjtCG
