Hi!
I’m busy customizing the theme and found out that when the logo is uploaded, the quality is less than the original.
You can see the difference in my test-invironment: gadgetreview.eu and the original at gadgetgoeroe.nl.
And yes, I’m 100% sure that I’m uploading a high-res version of the logo. Does this theme do anything with the uploaded header to make the filesize smaller or so? What’s the cause of this behavior?
Regards,
Roeland
The actual file itself is untouched http://www.gadgetreview.eu/wp-content/uploads/2014/01/logo3.png I think the CSS resize may have to do something with the fuzzy effect seen on Chrome. I can’t elaborate as my Firebug extension has chosen to stop working on Chrome.
Interesting… Chrome makes images blurry… Chrome breaks dev tools.
Bad chrome.
I swear I’m not making this up from my end π http://screencast.com/t/vMn69EZPVFN5
You uploaded this banner through the theme customizer’s logo field? Maybe the dev’s know something about this (possibly huge banners don’t go into the logo because they get resized? http://screencast.com/t/eLqrVwQlBHwJ ) If that is the case then it would be an easy fix to add your header another way through the template code.
As far as I know though, I’m stumped! Let’s see what they say π
Maybe it’s because the retina version shows up on a non-retina screen?
This is the header at 100% zoomed in http://screencast.com/t/TM6j1KGa8m and then 110% http://screencast.com/t/TM6j1KGa8m I don’t know but it looks like 110% is better?
What you can do is to make this image and overwrite it with original http://www.gadgetreview.eu/wp-content/uploads/2014/01/logo3.png to be sure the WordPress not make something with the image on upload process.
Make the image at 966px width as you can see here that is the require image size not 967px http://screencast.com/t/xg6Zv6Koz
Hope this help!
Yeah I know what you means. The visual composer is amazing and so is the review system.
And I spent 20 hours a couple of days ago building my site using Newspaper, so I know what you mean when you say you’re in the design stage π It’s tough but rewarding to take a site all the way from testing to final release π
