Low Quality Row Imagery
We are trying to recreate a page we created with a custom image for the row. This is for a header. But for some reason, this new build of the site, the image quality has significantly dropped although using the same resolution, can you help me with this?
Old Site: https://tinyurl.com/ywmg4647
New Site: https://tinyurl.com/ymhywl2s
Do you know why this could be?
Please check when you upload the image to see if it is full-size.
The resolution seems to be the correct size in the backend (1200×200)
https://tinyurl.com/yvuwjzqv
Please check the size wen you add the image as the background image.
Hi, I was unsure to do this but when downloading the image, I noticed it is pulling through as 300×50? Is there any way to change this in the row settings or somewhere else? As this image is a background for the Row
What is the size of the original website? You need to upload it as in my screenshot.
Unfortunately I may need some help, where can I find these settings? Thank you.
Please get in touch with us via email at contact@tagdiv.com and provide the wp-admin and where you want to set the image.
