Low scores on mobile theme ,amp and desktop pagespeed and gt metrics optimize
How should I minify my javascript, CSS, and HTML codes?
currently, I am using autoptimize for minification which doesn’t seem to be working according to the gt metrics, Lazy load by wp-rocket for lazy loading of images, the wp super cache for cache, and ithemes security.
I have used the mobile theme from the recent update of theme for the homepage and single post
website:https://hastysurf.com/
  • This topic was modified 6 years by KSARANG. Reason: Update
AMP settings
Hi, please check this answer from this similar topic -> https://forum.tagdiv.com/topic/low-scores-on-mobile-amp-and-desktop/
I haven’t been able to resolve the speed low issues
https://gtmetrix.com/reports/hastysurf.com/wS8yovWM
these are the results please guide
Try preloading theme fonts and optimize images.
Hope you will find this helpful.
On GT metrics it says minification of some tag inline, what exactly is it?
I have autoptimise in place or maybe I missed something in the settings.
by preloading fonts and optimize images? can you explain, please?
https://imgur.com/a/1k60Quj these are autoptimize settings related to inline and preloading which I activated after your response
I have a wp super cache with all recommended settings on
Lazy load in theme panel active
wp-optimise for database optimization ,site kit for google and ads are inserted in theme panel .
how to reduce HTTPS requests ? (SSL Active)
  • This reply was modified 6 years by KSARANG. Reason: update
Is using the inner row good for speed or bad?
I used inner rows a lot on the homepage and without preloading elements
How can i optimize
wp-content/plugins/td-composer/assets/fonts/td-multipurpose/td-multipurpose.ttf
and
wp-content/themes/Newspaper/images/icons/newspaper.woff?19
and remove unused javascript and css from my page ?
Suggest plugins or ways to do so Site : hastysurf.com
If you check the links above you see that in one topic @Amit provide a solution for how to preload the fonts, here is link to that topic -> https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/page/4/
Also using thee Autoptimize you can improve your website and EWWW Image Optimizer it can be use for a better results on your images.
Hope this will help you!
I am still unable to understand , can you make it easier for me to place the code?
which code and where should I place it ? and I am not using wp-rocket.
These are the links I get on page speed under the preload key-requests :
1- https://hastysurf.com/wp-content/themes/Newspaper/images/icons/newspaper.woff?19
2- https://hastysurf.com/wp-content/plugins/td-composer/assets/fonts/td-multipurpose/td-multipurpose.ttf
Also if I am supposed to add a code in function.php then do I have to simply add it in the end or in a specific space ???
please mention details in your solution please
In order to reduce the time for icons you need add this code in head section:
// Preload Newspaper fonts for responsive theme (main theme) function dns_prefetch_responsive()
echo '<link rel="preload" href="https://hastysurf.com/wp-content/themes/Newspaper/images/icons/newspaper.woff?19" as="font">';
echo '<link rel="preload" href="https://hastysurf.com/wp-content/plugins/td-composer/assets/fonts/td-multipurpose/td-multipurpose.ttf" as="font">';
add_action( 'wp_head', 'dns_prefetch_responsive', 0 );
This code can be set in a child theme in functions.php at the end of file -> https://i.imgur.com/KvX498h.png
In this way you do not need to do those steps after each theme update.
I have no child theme, how can I make 1?
Is it possible to paste it directly in functions.php in theme editor?
Is it possible to reduce site DOM elements?
If so, how can I?
Hello !
Every DOM is an element from your website. For a lighter website you will need to reduce the number of elements and modifications added to it.
@Calin
You gave me the code and I pasted it in the child theme functions.php file as you can see in the image attached.
can I insert it in the main theme functions.php, If yes then where should I add, and if I am supposed to add a code in function.php then do I have to simply add it in the end or in a specific space ???
like I asked in image-2 in given link
Hi KSARANG,
Yes, that code can be set in the main theme, in functions.php at the end of files, the file path is wp-content/plugins/td-composer/legacy/Newspaper/functions.php
Let me know the results!
Viewing 16 posts - 1 through 16 (of 16 total)
