Main menu and mobile menu not working, need help please!!!
Hi, I need help please!!!
For some reason the main menu and mobile menu are not working… I’ve been trying for 3 days to fix this issue but i can’t seem to figure it out… I am no web developer and do not have any coding skills, its my first time using WordPress. I’ve read on the forums and on wordpress forums and i think i’ve managed to do everything i should of done for it to be able to work. My site is http://www.fmxmag.com if you can please take look…
let me know where i can send you login credentials if needed. i really can’t figure this out
You need to create and set a menu as header menu: http://screencast.com/t/h7NTPYxpx
The mobile menu is build after the main header menu so this will also work after you set-up an menu.
You can read here about how to create a menu: https://forum.tagdiv.com/menu/
You should also consider going over the whole documentation to find the best ways on how you should use the theme.
i’ve read the whole documentation. im not crazy, i know how to read. i might not have no coding skills but i definitely know my way around. all that has already been done. wether its from that screenshot you sent me or from or from appearance-menus-manage location, iyts not working!!! i created a custom menu with my homepage and i added my categories to the menu as i want my categories to be pages, i see my custom menu in my admin panel, it just wont save my settings, something is definitely wrong. all that has been done, i read the documentation, i created everything else on there, im not stupid, it just wont save my settings
i almost feel insulted from that answer. its my fault for saying i have no coding skills. u think i havent tried that, click on the link where it says to create a menu, come on… how stupid do u think i am? everything is almost done, my categories, permalinks, theme colors, fonts, social sharing added to the site… i see my menus like stated in earlier, it wont save my settings. the minute i click on another tab or come to delete my cache, it doesnt save the settings
I’m sorry about that, I didn’t mean to insult or offend you. My answer was like that because when seeing this message: http://screencast.com/t/BIUpQyBgpMjs I initially tooth different as you haven’t mentioned that the settings aren’t saved.
If you haven’t tried already please increase the max_input_vars = 1000; value inside the php.ini file to max_input_vars = 5000;.
If you don’t have access to the php.ini file please contact the host administrator and let him know about this issue.
If this you have already done this and still can’t save settings please give us wp-access and send you login credentials at contact@tagdiv.com and specify your issue details or send a link to this topic.
Hope this helps! Please let me know and once again sorry for this!
