Main menu dropdown style problem
I’m developing another site using newspaper and using demo content everything is smooth except of (probably) styles problem in main menu.
Please see screenshot https://www.dropbox.com/s/e9ftlm9mf69w0bq/Screenshot%202017-04-01%2017.28.03.png?dl=0
Demo has been successfully imported, but in dropdown menu “normal” elements (not mega menu) don’t seem to have normal style (background highlight, font, etc.). For example “Urzędy” as seen in screenshot should have bold font, be highlighted, etc. As well as other dropdown menu elements.
Please help. Site is staged (production behind maintenance plugin) – I’ve checked without maintenance on but problem still exists.
Best regards,
Milosz
You can change the color properties for the sub menu items in the theme panel, like this – https://www.screencast.com/t/12rwOBNqcR3H
And also the font properties for the sub menu like this – https://www.screencast.com/t/6V40QeOd8X
Hello Simion,
thank you for fast answer.
Is it the new feature introduced in 7.8? Menu looks different than on other sites with 7.7
Best regards,
Milosz
Yes some of these are options available in the new theme version. You can check the changelog here
https://themeforest.net/item/newspaper/5489609
And also on the live demo – https://demo.tagdiv.com/newspaper/
Thank you. When updating, this enforces a bit of colour tweaking, but having more control is better.
Resolved. Best regards.
