Hi there i new to using this slider for the main page and was wondering if you can have a revolving image for the large article and then link the 3 smaller pictures to pages instead of posts?
regards
Byron
What you can do is to create 4 new posts, then add on each of them a specific tag, like my-special-tag then set the big slide to read that tag, add it in filter by tag.
Install a plugin that allow you to get an external URL for each post, and for that 4 posts you can set manually a custom URL that will be an URL to your page.
https://wordpress.org/plugins/page-links-to/
Thanks for your message!
Thanks for the tip! will play around and see how it goes 🙂
thanks heaps
