Major AMP issues began over the weekend, need help isolated
Something got majorly jacked with the AMP updates that went in on recent plugin updates.
I’m now showing over 2K errors … “a mandatory AMP HTML tag is missing from this document.”
Can someone please review livemusicblog.com? Help?!
https://livemusicblog.com/news/john-mayer-slayer-lot-t-shirt-grateful-dead-company/?amp
Seems related to Jetpack if that helps, I disabled and seemed like that started to re-do my Search Console validation fixes. May just leave Jetpack out of it once and for all. 😉
This can be a plugin conflict, please make sure that you do not have a plugin conflict, please deactivate all non theme plugins, also if you are using child theme or cache plugin, please deactivate them, clear all cache and try again.
Please make sure that all the settings are as in our requirements, please follow the guide carefully
– https://tagdiv.com/newspaper-theme-requirements/
Also please check the settings from Jetpack.
Same for us.. started 2nd of June and continuing until today
Hello @rrystrom,
Please provide some more details and some screenshots about the problem you are facing, also make sure that you have the theme updated and all theme requirements are set according to our guide – https://tagdiv.com/newspaper-theme-requirements/ and you do not have any plugin conflict.
