I want to make footer size smaller, thanx
Footer is resizing automatically, but you can limit the posts number that are appearing on the block.
For example Popular Category from your footer widget: http://screencast.com/t/gqNrPRlW
My footer before: http://screencast.com/t/w8b3ymW2MGln
And after: http://screencast.com/t/9ExccDdFHwT
The footer height is set depending of your footer content, you can use css to reduce or remove this padding as you like: http://screencast.com/t/rAtCx1n96N
Use this code in theme panel > custom css field:
.td-footer-wrap .span12 .td-grid-wrap {
padding: 20px 13px 0px 13px !important;
If this doesn’t help please let me know and also provide you site’s url as I need to inspect it to provide an accurate solution for this.
