Making the Entire Slider Clickable – Need Help
Hi everyone,
In our current slider on the desktop version, only the blog article’s headline is clickable. I’d like to know if it’s possible to make the entire slider (the whole image) clickable. Right now, when clicking on the image, the cursor only changes to the “hand” to slide left or right.
Thanks for your help!
Tom
Hello Tom!
Which shortcode do you use for the slide? Can you please provide more information about your issue?
Hi. I use the “Slide” shortcode. My wish is, for desktop, that the full image can be clicked to access the blog post. Currently, only the blog post’s headline is linked to the article. You know what i mean?
The slide is made like that so you can slide/grad left right on the image using the mouse.
here is a topic with a similar question – https://forum.tagdiv.com/topic/about-tagdiv-composer-slider/
Hmmm, thanks. Unfortunately, that is not a usable option. Firstly, it doesn’t work on mobile devices and secondly, the implementation is not good.
