Manual ordering of posts
Hi! I want to be able to order post manually. In what way can i do this with the newspaper theme?
Unfortunately I don’t understand what exactly you want to do with the posts. Please provide more details about the matter, for a more accurate answer.
If you want to customize the way blocks and grids display posts, this is a guide presenting all the available settings and options
– https://forum.tagdiv.com/block-settings-guide/
I want to use custom post ordering funcionality like this plugin:
https://wordpress.org/plugins/post-types-order/
Does these types of plugins work with the theme?
I could not say if it will work or not. We have not made any tests between the theme and such plugins. You could install it and configure it, then make tests with it. Check if everything works properly.
