Manual Related Posts
I need to manually choose which post show in widget, how can I do?
The theme doesn’t have such a function, you can only select a certain category or sort them by tag. You could add a certain tag to the posts you want to display and add it on the block/widget setup section – http://screencast.com/t/Ni1ZIRJJ
Thank you, Emil G.
I know but i need to choose wich post show in widget, you can’t help me? there are many plugin that resolve my problem but i don’t want add many and many plugin.
There is no option within the theme to specifically select posts to be added to a widget or block so you need to set a tag to those posts you need inside that widget then use the tag filter to get those posts to the widget.
ex:
* http://screencast.com/t/8Yui3Xckr
* http://screencast.com/t/TKqbDzrkws
result: http://screencast.com/t/sfiIgd4St6
