I have newspaper theme v6.2 installed on my website.
URL : http://www.naukrinama.com
While I am creating a post and publishing it, currently the related articles automatically get selected and gets shown on the published post.
I want to do this manually in which I want to select out the Related articles myself. Let me know how can this be achieved.
Probably best to use something like Advanced Custom Fields and make a custom field set where you can paste in the articles you want to link to manually, then put the shortcode for that at bottom of the post template(s) you’re using.
There might be a plugin for this, but I have not seen one.
Unfortunately the theme doesn’t have an option to do this and you will need custom modifications, it is not an easy task so I suggest to hire a professional developer to do this for you as we cannot provide custom work. Here is the related articles function if you want to modify it – http://screencast.com/t/HLre7v3VYq Or try to use a plugin like Christopher suggested.
