I’ve recently purchased the newspaper theme.
Automatic updates of the required plugins failed.
I’ve tried the manual method as well which seems to be not working as well
Installing the plugin…
Destination folder already exists. /srv/htdocs/wp-content/plugins/td-composer/
Plugin installation failed.
Hello !
We are sorry for the inconvenience !
You will have to go into your cPanel and manually delete the folder from your issue
It appears that wordpress was unable to delete it before updating.
Please let me know how this works for you !
Thanks for your reply.
CPanel doesn’t seem to be opening for me
can you suggest something else?
I have purchased & installed the theme through wordpress directly
Can i Please get some help,
i’m unable to update the plugins automatically & manually
Thanks for your reply,
Wordpress is my host, so how am i supposed to open or enable cpanel?
Hello !
I’ve made some search and found out this: https://www.screencast.com/t/Ywt0QSVLbyNq on this link: https://en.support.wordpress.com/ftp-access/
So you will have to contact wordpress team and display your issue to them. After they fix you issue please complete all the system requirements of the theme as mentioned above and then everything should be in order.
I hope this was helpfull !
