Marge problems
Hello
On the homepage I changed elements of the theme like the menu and big grid.
https://www.virtualmagie.com/
Till then the bid grid is praticaly under the menu.
I tried to erase all Custom CSS to find the reason but it change nothing (of course, I kill the cache and tested on secure mode).
Do you have Custom CSS to correct that please?
Regards
The page template you are using, the menu overlay template, this will position the header over the page content. That is what is supposed to do.
I see there is a margin top set for the grid, but that is still not enough to make it fully visible
– https://www.screencast.com/t/eKAorTEkFj
Try to edit the page with the composer and increase that margin value. Or maybe consider changing the page template.
Hello
Thansk for your solution.
Regards
So in fact, it need to let in Default mode.
So I erased all margin elements.
There is still bug on TC. I will list in another thread.
If you opened a different topic we will take a look there.
