.td_block_9 .td_module_8 {
padding-bottom: 0;
margin-bottom: 0;
.td_block_17 .td_module_8 {
padding-bottom: 0;
margin-bottom: 0;
Am using the above code on theme panel under custom code to remove margin or spacing between one title and another and its working fine.
What i need is to edit the default file and stop using the above code on – under custom code, i have tried to edit the style.css and its not working.
You can guide me where to edit the default file. The main reason is to avoid double loading on the css.
