Hello all,
I have two problems on my frontpage at http://www.stratego.hr . As you can see (http://www.screencast.com/t/AQrU8fiuAgZ ), there is no blank space between main post and editors choice block (red circle), and there is so much blank space between editors choice and ad block and posts section (blue circle). How to solve it – make a blank space between different objects and remove or decrease blank space at the end of the section?
Thanx in advance!
You can add a margin from row’s design option: http://screencast.com/t/a18LhJZMO6 – http://screencast.com/t/C0TJadim5
The blank space appear because you have three empty rows after block: http://screencast.com/t/OTJzYOYGBMC Try to remove these rows from Visual Composer then test the page again.
Hope this helps.
