Massive difference between browsers
I’ve just updated on latest version and there is a BIG difference in page look from Edge / Safari / Chrome / Opera
I’ve worked whole day on edge and now I went to try and see how it looks like on other browsers and I was puzzled about the difference [ since they are all chromium afaik? ]
I’ve activated https://demo.tagdiv.com/newspaper_downtown_pro/ theme and changed categories for my needs
Please open http://www.sisak.info in different browsers or check here https://imgur.com/a/NSKOcn2
Any ideas what is happening that render is so different ?
Also, my global header got top bar and it just appears for a sec and than disappears ..
Hello @cyberhrc !
I’ve checked your website, and I can see the same section in every browser.
Did you clear the cache from your browsers?
Hi again
Sections are there but look at the difference in font rendering (check screenshot)
Cache is clear on all browsers
Edit
All fixed now [ cache was clear in time of posting text ]. Have no idea what happened 😀
Only thing now is that top bar [ scroll few time up down and look at header menu ] . Top bar should dissapear
Hello @cyberhrc !
Edit the homepage with the TagDiv Composer and delete that row.
Oh sorry Betina i was to tired to realize what I wrote.
So … Top bar SHOULD NOT disappear
Go on sisak.info , let it load, you will see my town name + temperature on left and on right few items + social network icons
But as soon you scroll down [ and go back up ] that top bar is empty [ white bg only ]
In template that bar is there
Hello @cyberhrc !
You don’t need to scroll. The top bar disappears after the site is fully loaded.
Do you use some custom CSS on that header?
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
