Max CDN compatibility 3.8.4
Version Newspaper 3.8.4
WordPress 3.9.1
website : http://riddimtunup.com/
Since I have update to the 3.8.4 version, my website look like broken when MaxCDN is activated.
website broken
Could you help me to fix it.
Many thanks
Best regards
Typically after a major update to any theme, I find I have to “expire” the existing cached content on our CDN, so that the CDN captures and caches the NEW content.
Many thanks Christopher, problem solved.
  • This reply was modified 12 years by ewing.
