Media Grid with custom URLs?
I have a media grid of four photos on a page. I’ve set custom URLs for each image in the media library. When you click on the photos, a new window opens with a slideshow of the four images. How do I instead make it that when you click on each one, you go to the custom URLs?
The Media Grid is a Visual Composer element and it doesn’t have an option to add custom links you will need custom modifications to the plugin’s files to change this and it is not so easy. For example you can use Image Gallery, this is also a VC element, but it allows custom links for each image – http://screencast.com/t/5A9kNL8tQb3o
Thanks! I got around this by inserting individual photos into columns and linking each one.
