Hi, i have a problem with mega menu. If you hover on menu you can see the problem. It is on ss also. Thanks.
That happens because you made mega menu an item which also have sub-menus. Try to remove the sub-items for your first menu item then test the page again: http://screencast.com/t/VGavWZz3i
HI
Please follow our documentation and make sure that you set the mega menu as it’s indicated here: https://forum.tagdiv.com/mega-menu/
Let us know how it goes and if the problem persist please send us an email at contact@tagdiv.com with your login credentials and we will inspect this issue as soon as possible, also include a link to this topic.
