Mega Menu Issue with Microsoft Edge
I have a Mega Menu Issue with Microsoft Edge, the bottom of mega menu goes to the bottom of page, however with Chrome and Firefox, everything is ok.
https://imgur.com/a/8MGwKu5
How can I fix this ?
thank you
  • This topic was modified 6 years by gumball44.
Indeed on your website the mega menu act strange on edge, I’ve just checked our demo an this is working normally -> https://i.imgur.com/gX1Dspi.jpg
Please make sure that you do not have a plugin that caused this problem.
Let me know the results!
I deactivated all plugins except tagdiv plugins, cleared cache, and nothing changed on mega menu.
I erased custom css on mega menu, nothin changed..
Any other idea ?
Please send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
I did, waiting for your answer.
Kind regards
I’ve search in our email and I do not find the any email from you regarding this problem, sorry!
Please send again an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
I just have sent it again via contact@typemeon.com to contact@tagdiv.com
Thank you
Did you check my mail ?
What you can do is to insert the custom code directly in the function file from wp-content/plugins/td-composer/mobile/amp/functions.php like this -> https://i.imgur.com/j5Ugu9A.png in this way the code should apply.
???? I’m speaking about edge navigator on this topic, not about footer logo.
  • This reply was modified 6 years by gumball44.
Sorry was my mistake,I thought you were referring to the same problem as in the preview topic, sorry for the inconvenience!
We have two emails from you -> https://i.imgur.com/cwMxppj.png and both are solved -> https://i.imgur.com/QZOFfVh.png -> https://i.imgur.com/4684szQ.png
these are formers email, I swear I have sent you new emails with contact@typemeon.com, it’s about edge problems and footer logo amp, please check in spams.
first mail “reduce size logo”:
lun. 23 déc. 2019 08:50
second mail ” mega menu issue edge
Unfortunately I do not find these emails, only the above ones.
The problem with the menu seems to be form some settings that are made on the header menu, I’ve set a custom css to fix that setting. -> https://i.imgur.com/QH4SiHO.jpg
Also I’ve set the code in the file for resize the amp logo -> https://i.imgur.com/hpBHrxO.png -> https://i.imgur.com/dyCKXIg.png
Hope this is what you want to achieve!
Have a nice day!
Hi Calin,
Microsoft edge problem seems to be fixed, Thank you for your help.
However Footer size logo AMP is still here for me, even if I clear cache. Logo size doesn’t change, furthermore your code breaks header alignment. I use Samsung A32017 mobile.
https://imgur.com/a/4VxT057
https://imgur.com/a/TzhVNd4
For me this is displaying normal -> https://i.imgur.com/UrcTp1E.png -> https://i.imgur.com/3GIExbZ.png maybe all it need some time until all cache is clear/change, please clear all cache you have on website and browser and try again.
