Mega Menu problem
I have a problem with Mega Menu. My menu appears on some pages but not on others.
For example, Mega Menu is visible on the home page but not on this page.
I noticed that this bug also prevented using the search engine and blocks pagination widgets.
Have you ever encountered this problem?
Thank you for your help.
please disable revolution slider if you are not using it or the speed booster plugin. The two plugins are incompatible with each other for now 😐 but I’m looking to fix them.
Radu O.
I managed to disable both plugins
