The mag menu iz showing black background when the next and the previous button iz seems to show a black back ground… Check shoutershub.com and check the tech mega menu and u wuld see a navi button… When you click on it you wuld find out dat it iz very disorganized…
I have tested your site and haven’t found any black background in mega menu and it looks fine now: http://screencast.com/t/zPFg7bK2Of
For the images that don’t look right like the one I pointed in the screenshot you should use the “Regenerate thumbnails” plugin and regenerate all your thumbs and also make sure that you use an image larger enough to fit all containers.
@lucian , try using the next page on any of the mag menu u pointed @ and you would find out what am saying is just tru its so anoying…… Or click any of the category cited above.
eloo lucian, you are awesome, amd sowei but i saw the fault was from me, i used a public PC (cafe) and an Updated Firefox browser (Laptop) and saw the mag menu was ok like nothing happened to it.
Thanks – You good men
